Multifunction DAQ
Genetic algorithm for use within LabVIEW
I want to use a genetic algorithm to optimise a control system.  I was going to use MatLab because I can write the GA with that, but I cannot get it running fast enough with my C-DAQ.  The alternative is to use LabView, but I could not write a GA VI.  Do you know of a GA for use in LabVIEW?
(6,371 Views)
Hi Jack@Newcastle,
Take a look at the following example of Genetic Algorithm implemented in LabVIEW (https://decibel.ni.com/content/docs/DOC-13699).It should give you an idea how to write your own code.
Edvin
(6,236 Views)
