Multifunction DAQ
Generating hardware trigger (TTL) by looking at analog input values
Is it possible to generate a trigger signal when my analog voltage level instantaneously switches from 0.2 to 0.6? My application requires me to send a trigger to a camera as soon as I see the rising edge of the analog pulse I generate. I can generate a soft trigger in the code, but that would be too slow for me. Normally I would design an opamp circuit that would sense the voltage change, but this case I want to see if this is possible with a simple DAQ card, such as 6009.
(3,901 Views)
diehardOE
It is certainly possible.  What software would you be using to configure the card?
(3,885 Views)
The 6009 doesn't have an analog trigger circuit--the best you could do is the software-issued trigger that you mentioned would be too slow for your application.
Other DAQ cards which have analog triggering capabilities (e.g. 635x, 636x, 9205) would be able to issue a hardware trigger signal by exporting the analog comparison event (see X Series User Manual).
Best Regards,
John Passiak
(3,855 Views)
We will use Labview. We called in NI support and they recommended X Series NI USB-6341 for this purpose.
(3,849 Views)
would NI USB-6341 work as well?
(3,847 Views)
The USB-6341 actually doesn't have analog triggering either (see specs).
Any 635x or 636x X Series would have analog triggering (e.g. USB-6351).  The 632x and 634x do not.
Another option would be to use the USB-9171 sleeve with a USB-9205, but the X Series would be much more flexible if you needed it to do other things.
Best Regards,
John Passiak
(3,844 Views)
