Multifunction DAQ
Generating 4 analog output waveforms with different frequencies
Hi John,
                  The vi has been modified according to you suggestions. Now it is generating AO and DO in sync!!!. There might be few modifications required in future, if i have any questions i will post back them in this thread.
Thanks a million!!!
Regards
Viswa
Message 41 of 65
(2,262 Views)
Hi John,
                 I want to control each waveform parameters such as frequency, amplitude and phase independently, i can do that using numeric controllers. But i want to change frequency and amplitude while vi is running so i tried to use control KNOB instead of numeric control. The problem i cant control data range independtly for each of the elements. Could it be possible to implement it?
What i mean is that i want to have variable control knobs with different maximum and minimum values for all parameters in every array.
Suppose i want to have frequency for two waveforms say maximum to 10000Hz can be variable in steps of 100, where as  for other waveform i want to have maximum frequency 50 only and can be varible precisely in steps of 1.
Message 42 of 65
(2,172 Views)
There is no difference between a knob and any other numeric control. To set the range and increment, right click on the control and select Data Entry. Uncheck the 'Use Default Limits' and set the min/max/increment to whatever you want. You can also set these with property nodes.
Message 43 of 65
(2,159 Views)
Hi Dennis,
                         I did try the method that you are explaining but if you look at the vi attached in the previous page ver 2.0 you might get what i am trying to explain. If i change max and min value to any one of the knob control, all other knobs get the same settings. I just dont want that to happen.
Thanks for your quick reply.
Message 44 of 65
(2,156 Views)
I don't see any VI with knobs - just some image. In any case, there was a bug in earlier versions of LabVIEW where the property page for onc control appeared for all. This bug has been fixed. I don't remember exactly but I think the work around was to use property nodes.
Message 45 of 65
(2,148 Views)
First of all, whether the control is a knob or a text field you can still change it on-the-fly.
It sounds like you prefer the knob (which is OK), but you want to have different max/min values on the different knobs.  The problem is that the control is an array of knobs (each element in the array is a cluster with the desired waveform parameters--the idea was that this would be scalable to any number of AO channels).  I don't know of a good way to change the scale of knobs in an array element-by-element.
If you want to have different knob scales for the different channels, I would probably use a cluster control for each rather than having one array of clusters.
Best Regards,
John Passiak
Message 46 of 65
(2,144 Views)
Ah, I missed seeing that the image was an array of controls. Sorry about the confusion.
Message 47 of 65
(2,139 Views)
I had a feeling, it's hard to tell sometimes from a screenshot (it helps that I wrote the code in the first place).  Thanks for posting anyway!
John Passiak
Message 48 of 65
(2,135 Views)
Hello John,
                    You are right about using cluster of waveform parameters individually for each waveform than using array of waveforms.  I have modified the vi with my requiremnets and worked well, only the remaining thins is to implement triggering at rising or falling edge. Iknnow that its straight forward to implement.
I never understood the link https://forums.ni.com/t5/Example-Code/Two-Analog-Output-Waveforms-With-Different-Frequencies-and-or/...
I had always a question about  multiple waveform generation. Does my task need to define any buffer lengths as explained in the above link??
Thanks for the help!!
I guess you have the sub vi Generate PWM.vi
Message Edited by viswa on 03-18-2010 06:59 PM
Message 49 of 65
(2,095 Views)
I would like to use my DAQ 600USB to measure the resistance wires. You have an example VI?
Message 50 of 65
(2,093 Views)
