Multifunction DAQ
Generate sweep sine from 1hz to 20khz on ni9263
I tried to generate a sweep from 1hz to 20khz with NI9263 setting the sample clock at 100khz but connecting the oscilloscope I see a sinewave not smooth already at low frequencies around 1000-2000hz. I tried to put a low pass filter after the daq and the situation improved. Is this the solution?
(3,507 Views)
could you please be a bit more specific?
Which grade of deterioration are you experimenting?
Could you please provide some screenshots and possibly the .vi that you're using?
Thanks in advance
(3,427 Views)
Hi this is what I see on the oscilloscope for a 20kHz wave at 100000 sample clock. The vi is this.
(3,417 Views)
HI,
If you're generating a sine wave at 20KHz with only 5 points for period I do not expect I very smooth signal.
I'd like to see the "dirty" sine function at lower frequencies, you wrote about a bad output even at 1KHz and this seems to be strange. Could you provide me some screenshots?
Moreover if you put a lowpass filter at the output you'll obtain a smoother transitiion fore sure, but you will not gain resolution. So the question is, why you need to have a smoother signal? Is this sine output reused somehow?
Regards
(3,409 Views)
At 1 khz the signal is much cleaner. I have to enter the signal into a shaker and make the signal fft to find a frequency response. What frequency of cut should I give to the low pass possibly.
(3,405 Views)
