Multifunction DAQ
Flexibility in Scanning Directions
 I appreciate your guidance on using a "save for previous" option, but unfortunately, I am currently limited to using LabVIEW 2024. To clarify my needs, I am looking to create flexibility in scanning in both directions, but not dynamically during a scan. Instead, I want to be able to change the scanning direction for each new scan by interchanging the rows of the array. Adding a case structure to swap the X and Y arrays between scans sounds like a viable approach, and I will definitely explore that option. I understand that this question is more programming-oriented. If you could move my thread to the LabVIEW forum for further assistance, I would greatly appreciate it. Thank you once again for your help!
Devv
Message 1 of 1
(168 Views)
