Multifunction DAQ
Finite digital generate waveform
Why is this not working?  Seems to run fine in simulated mode but doesn't output digital when on target hardware (NI-6220).  I know that digital doesn't have a clock so using AI Sample Clock.  Do I need to route the sample clock to a PFI line?  Simplfied code is in LV 8.20.
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(3,004 Views)
Hi Matthew,
You’re absolutely correct about the timing and just about have it. Because you’re using the AI sample clock, you need to set up an AI task to start the clock. I’ve modified your VI and attached it to this post.
Please post if you have any questions. Have a great day!
Ryan D.
District Sales Manager for Boston & Northern New England
(2,986 Views)
