Multifunction DAQ
File creation date
I know we can check a file's last modified date using the File/Directory info vi, but how do we check a file's creation date?
I'm using LV8.2 Thanks.
Message Edited by ATMA on 09-13-2007 12:54 AM
(3,185 Views)
Hi ATMA,
Unfortunately, there is not built in Vi that can give you the file creation date. You can still retrieve the file creation date by making a few calls to KERNEL32.DLL. There is an example implementation on the discussion forums that should be helpful located here.
Cheers,
Emilie K | Applications Engineer | National Instruments
(3,168 Views)
Thanks eek, i've found those threads. Should have searched first before i posted, sorry.
(3,163 Views)
