Multifunction DAQ
Fastest sampling speed using NI6211
Hi!
I'm trying to set up my first USB cDAQ (9172). I'm using three 6211 (thermocouple modules) and one 9205 (voltage module), they are mounted on the "rail". Eveything works great.
Unfortunatly didn't I notice that the thermocouple modules are not capable of simultaneous sampling before buying these. However, instead of sampling with 14 samples per second on all four thermocouple inputs I now would like to get 7 samples per second and use two channels instead of four. Is it possible using this setup? When trying, I'm only able to get maximum 4 samples per second when using two channels.
I'm using LabVIEW 8.20 and the hardware mentioned above.
Any help would be gratefuly appreciated.
Mattias
Message 1 of 1
(3,297 Views)
