Multifunction DAQ
FTDI FT4222
I am trying to use an evaluation board of FTDI FT4222EV by calling the d2xx.llb and ft4222.llb functions. As a start, I am able to set and read the clock setting, which I think means the communication is ok. But when I call the "SPI Master Init" function and try to change the clock polarity, the output of the CLK pin is always low even I set "CLK_IDLE_HIGH", and the function status return is "OK". Please give me some idea about what could be missed.
Thank you.
(3,327 Views)
Hi rumor,
both the board and the library are provided by a 3rd party so I doubt anyone here will be able to help you without seeing the code.
Please at least post screenshots, so that we can see what is happening.
(3,291 Views)
