Multifunction DAQ
External trigger
Hi, how can I configure one channel of my 6023E board (if possible) or 6036E board, in order to have an external signal to start ADC sampling?
What I need is to have one signal to sample and a second one to start the conversion (and then save it's value in a buffer). On the online help looks like it is possible to connect AI Clock Sample Signal and AI Clock Convert Signal to inputs, but I cannot figure out how.
Under MAX I cannot find any setting to be changed.
Any help will be appreciated.
(3,224 Views)
just a few questions: how do you program your device? Maybe in LabVIEW?
Remember that your devices do not support analog trigger so you have to use a TTL signal
in order to trigger an acquisition.
Bye,
Matteo F.
(3,190 Views)
