Multifunction DAQ
Event Structure
My application should be that the graph will generate readings for 10 seconds ( the graph move for about 10 seconds ) then analyse and read it back.
But it doesn't work that way. The graph show for only 1 seconds ( I guest ). Could some body help me with it
(2,522 Views)
The delay structure within the one while loop in your program seems to be unneccessary and confusing.
If you want your simulated signal to be generated for a different time period, then you can double click on the Simulate Signal express VI and increase the number of samples after unchecking the automatic checkbox.
(2,522 Views)
