Multifunction DAQ
Error1 - Invalid path when building executable
Hi there. I built this application to measure impedance of a device. The application works with the Multifunction DAQ and a third party digitize card. The source works great with no problems. However, when i move on to building an executable, i get the following error:
Error 1 occured a C:\ Program Files\National Instruments\LabVIEW 6.1\vi.lib\DAQ\lvdaq.dll - Invalid path.
Possible reasons:
LabVIEW: An input parameter is invalid
or NI-488: Command requires GPIB controller to be controller in charge.
I have tried checking the permissions on the dll file, verified the path and also ensured that all the 'Call library Function Nodes' are using the right dll. I removed the dll file from its location and the builder complained that it could not find the file. This verified that the builder is able to see the file. But i am not sure why it claims the path to be invalid. PLEASE help.
(3,057 Views)
Are you able to reproduce this behavior on multiple computers? I have tried several things to recreate this error using LabVIEW 6.1, but have not had any success. If it can be reproduced on multiple computers would be it possible for you to post a small example that demonstrates this error?
Thank you,
Scott Y.
NI
(3,043 Views)
