Multifunction DAQ
Error code -200088
I have a problem with DAQmx  version 8.3 (aqusiston card PCI-6133). I try use this function (in Delphi 7) DAQmxCreateAIVoltageChan(...) and I get error -200088. Anybody can help me? Thanks you
(4,083 Views)
That error code means
"Task specified is invalid or does not exist".
Did you remember to create a task before creating an AI channel?
(4,066 Views)
Thanks, I solve this problem. If you use delphi you should write as folowing:
var Task :PLongint;  Error :Longint
begin
  //function DAQmxCreateTask(taskName:PChar; taskHandle:PLongint):Longint; stdcall;       from  nicaiu.dll
  Error:=DAQmxCreateTask('Analog Input', Task);
 // and now you can create AI channel
but this  code not working, solution is very simple
var Task,  Error :Longint
begin
  Error:=DAQmxCreateTask('Analog Input', @Task);
DAQmxCreateAIVoltageChan(Task,'Dev1/ai1','P0', DAQmx_Val_Coupling1_DC,10,-10,DAQmx_Val_VoltageUnits1_Volts ,nil);
(4,036 Views)
