Multifunction DAQ
Error code 100 - erroneous data when use the "read from measurament file"!
Hello. I record an data from my EMG amplifier with daq scb-68. When recording i used "write to measurement file" tool and i record my data as "test_1.lvm". Then i wanted to see my data on real osciloscope, so i used my daq's analog output. In my block diagram i used "read from measurement file" tool and daq assistant for output. In the preferances of the "read from the measurement file" tool i chose the my ex data's filepath as filename and file format is text(.lvm). But when I run the project it gives me an error. The error is that:
Error 100 occurred at Read From Measurement File->Untitled 2
Possible reason(s):
LabVIEW: File contains erroneous data. This normally is a user data file.
When I search on the forum there are a lot of unsolved problem about that. What is the problem? Can you help me please? Thanks in advance.
(3,172 Views)
No one helped but I solved the problem and I am going to share maybe anyone needs. Problem is the format of the recorded file. On the "read from measurement file" VI  I did the settings that i share on the picture below. You need to click the "First column is time channel "  and than desimal point as "comma". I hope it helps. oldu.PNG
(3,146 Views)
