Multifunction DAQ
Error -89137 for AO when also doing synchronized AI
My equipment is a PXIe-1075 chassis populated with a PXIe-8130 controller and several PXIe-6259 cards, running LabVIEW 8.5 with Windows XP Pro.  I am trying to acquire synchronized analog voltage data from the ai lines, and this is working great.  However, meanwhile I am also trying to set the voltage of an ao line, and am getting an Error -89137.
I am using the example code "Multi-Device Synch-Analog Input-Cont Acquisition.vi".  When I select some Physical Channels and set the Synchronization Type to "M Series (PXI)" and run it, I get Error -89125, so I  have modified it slightly, where the "Get Terminal Name with Device Prefix.vi" has been replaced with "DAQmx Export Signal (Most Signals).vi" and wired with "Start Trigger">signal and "PXI1Slot2/PXI_Trig0">output terminal.  I have also changed "DAQmx Start Trigger (Digital Edge).vi" to be wired with "PXI1Slot2/PXI_Trig0">source.  See attached VI.  Running this slightly modified code works great, no problems.
While that code is running, I now also run the example code "Gen Voltage Update.vi".  When I do this, I get Error -89137.  How do I avoid this error?
Thank you for any assistance you can offer.
Chris
(4,356 Views)
NI helped me to resolve this issue.  See attached VI that resolves the problem.
(4,347 Views)
I have labview 8.2 and have the same problem. Can you post screenshots of your code Test.vi so I can look at it? I can't open Labview 8.5 codes.
thanks!
(3,945 Views)
Here is a screenshot. Unfortunately I only have access to LV2011. A number of VIs that came with LV85 have changed names or are no longer available, hence the missing icons. I've labeled the missing ones in the screenshot. Hope it helps.
(3,942 Views)
