Multifunction DAQ
Error 89130
I have PXIe-8880 with "RT" OS, I have some "CAN, LIN & Mulitfunction" DAQ, In MAX (Measurement & Automation Explorer) I am unable to run the test panels (Its giving the error as attached the image). I tried reseting the device, Self test is working and I changed the slot and re-install the drivers, still its getting an error. Any solution for this error please.
(4,847 Views)
Hi Samarj, have you tried the steps listed here?
What versions of the RT OS, DAQmx, and other software do you have installed? Can you open Test Panels on any other modules?
(4,810 Views)
Hi Chantastic,
Thanks for your reply. I tried these too. Still giving the same error. But I am not getting this error when calling from LabVIEW and Veristand Smiley Happy , I am getting this error only from MAX Test Panels. I tried re-installing DAQmx driver too. But not working.
(4,799 Views)
Hi Samraj,
Could you please give below details
Labview version
Os version
NI max drivers version to understand the issue better.
M.Kishan
NI India.
(4,780 Views)
