Multifunction DAQ
Error 50202 with DAQmx and .NET API
We are using .NET API of  DAQmx v9.8 and a NI PCI-6122 Card
Our program perform 256 data acquisitions of variable time duration.
  • 2 simultaneous channels, 500 KS/s
  • Time duration (2-3 min) per data acquisition
Each measurement is triggered from an external trigger signal to synchronize with other devices and it is stopped when a specific event has been reached.
We are creating a single task at the initialization (out of the loop), and this task is started with the trigger signal and stopped by the event.
We get an error 50202 after a large number of acquisitions (> 200 in most of times) and in some cases it works fine.
NI Platform Services: A system call returned an error. The operation could not be completed as specified.
Task Name: _unnamedTask<1>;
Status Code: -50202
The pseudo code is:
ConfigureTask();
for i=1 to 256
   ConfigureCard();
   StartCardMeasurement();
   StopCardMeasurement();
DisposeCardTask();
Some points that we have already tested:
  • We have tested in different computers with different motherboards (Not AMD). It is also tested with simulated AD Card (NI MAX).
  • We have tried to create different task each measurement and there is an error with the task creation (>100 task)
  • We have reviewed all the similar post available in the forum with similar problems:
https://forums.ni.com/t5/Multifunction-DAQ/Error-50202/td-p/797498
http://digital.ni.com/public.nsf/websearch/E80A8BB9D576EB058625724B0080B9B2?OpenDocument
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9KuSAK&l=en-US
http://digital.ni.com/public.nsf/allkb/61060FCCEFD2D5EF86257337005B9ED7?OpenDocument
This is the code of the main functions:
public bool StartCardMeasurement()
                try
                    if (this.runningTask != null && this.IsConfigCardDone)
                        //Start card acquisition
                        this.runningTask.Start();
                        return true;
                    return false;
                catch (Exception ex)
                    this.execInfo.InsertErrorMessage(ex);
                    this.IsConfigCardDone = false;
                    return false;
public bool StopCardMeasurement()
                try
                    if ((this.runningTask != null) && (this.IsConfigCardDone))
                        //Stop card acquisition
                        this.runningTask.Stop();
                        //End task
                        this.runningTask = null;
                        //Confid Card reset
                        return true;
                    return false;
                    return false;
public bool DisposeCardTask()
                try
                    //End task
                    //Releases all resources used by Task
                    this.mainTask.Dispose();
                    return true;
                    return false;
public bool ConfigureTask()
                try
                    //End other tasks
                    this.mainTask = null;
                    //Create a new task
                    this.mainTask = new Task();
                    //Create a virtual channel 0
                    this.mainTask.AIChannels.CreateVoltageChannel("Dev1/ai0", "", (AITerminalConfiguration)(-1),
                        this.MinSignalValue, this.MaxSignalValue, AIVoltageUnits.Volts);
                    //Create a virtual channel 1
                    this.mainTask.AIChannels.CreateVoltageChannel("Dev1/ai1", "", (AITerminalConfiguration)(-1),
                    //Configure the timing parameters
                    this.mainTask.Timing.ConfigureSampleClock("", Convert.ToDouble(this.SamplingRate), SampleClockActiveEdge.Rising,SampleQuantityMode.ContinuousSamples, this.SamplesPerChannel * 100);
                    //Configure the Every N Samples Event
                    this.mainTask.EveryNSamplesReadEventInterval = this.SamplesPerChannel;
                    this.mainTask.EveryNSamplesRead += new EveryNSamplesReadEventHandler(this.mainTask_EveryNSamplesRead);
                    //Start Trigger enable?
                    if (this.IsStartTriggerEnabled)
                        // Configure Start Trigger
                        this.mainTask.Triggers.StartTrigger.ConfigureDigitalEdgeTrigger("/Dev1/PFI0", DigitalEdgeStartTriggerEdge.Rising);
                    //Configure TDMS Logging Samples per file
                    this.mainTask.Stream.LoggingSamplesPerFile = MAX_RAW_SAMPLES_PER_FILE;
                    //Change buffer size
                    if (this.ActiveMeasurementType == MeasurementType.HOL)
                        this.mainTask.Stream.ConfigureInputBuffer(this.SamplesPerChannel * 100);
                    else if (this.ActiveMeasurementType == MeasurementType.PNTCAL)
                    else
                        this.mainTask.Stream.ConfigureInputBuffer(this.SamplesPerChannel * 10);
                    //Verify the Task
                    this.mainTask.Control(TaskAction.Verify);
                    //Create the reader object
                    this.analogInReader = new AnalogMultiChannelReader(this.mainTask.Stream);
                    return true;
                    return false;
public bool ConfigureCard()
                try
                    //Config Card as not done
                    //End other tasks
                    //Config tasks
                    if (this.runningTask != null)
                        this.execInfo.InsertExecutionInfoMessage("IndraHoloCardDriver.dll", "HIGH", "typeSystemError", "ConfigureCard()", "runningTask != null");
                        return false;
                    //runningTask as mainTask
                    this.runningTask = this.mainTask;
                    //Use SynchronizeCallbacks to specify that the object marshals callbacks across threads appropriately
                    this.runningTask.SynchronizeCallbacks = true;
                    //Reset processing counter
                    this.ProcessingCounter = 0;
                    //Reset AD Card counter
                    this.adCardCounter = 0;
                    //Reset test process time
                    if (this.IsDebugDataEnabled)
                        this.testProcessTime = 0;
                    //Config card is done
                    this.IsConfigCardDone = true;
                    return true;
                    return false;
Message 1 of 1
(4,348 Views)
