Multifunction DAQ
Error 50011
The board I use is PCI-4462, Windows 7.
Computer equipment management can identify 4462 normally.
But in "devices and Interfaces" in NI Max software, 4462 has an x.
Error code 50011, specifying that the count is too small or too large, or that the size of the interval used for the read operation is incorrect. Other offsets that also specify the maximum count may come from this offset. The operation cannot be completed as specified.
The replacement of the drive and system cannot be solved.
(1,317 Views)
Hi, were you able to find a solution for this? We are also facing the same issue and not able to find a solution.
(423 Views)
