Multifunction DAQ
Error -2147467259 - VI Logger Execution Error
When click Run task using Ni-DAQ 6.9.3 and VI Logger 1.0.1 I get messege " VI Logger Execution Error - Could not start task
Can you help?
(3,855 Views)
Hi AutoSafety,
I am believe that the NI VI logger is no longer supported but also I was checking the documentation and one of the common issues is that you are not able to run two tasks at the same time if you are using different devices or if you have another task. Another thing that you can try is to reinstall your DAQ version.
Sil.VI
(3,827 Views)
