Multifunction DAQ
Error 200329 using USB DAQpad 6016
Hello ,
I get error 200329 while running data aquisition using USB DAQpad 6016.
I am using the analog input, analog output, digital out and counter (see attached file)
System environment is:
Windows 2000, Labview 7.1, DAQ Driver 7.4.
Any help or hints are much appreciated.
inka
(3,223 Views)
how you configure the daqmx tasks?
what´s happening in the missing sub_vi?
(3,215 Views)
Thanks for your respond:
In the meantime I found a solution to my problem:
Each task has to be  terminated individualley in a frame of a sequence structure.
(3,203 Views)
