Multifunction DAQ
Error 200279 from continuous TDMS data logging
I am trying to acquire analog voltage information from 31 channels using two PXIe-6368 cards synchronized via master and slave concept. The data is continously streamed into an array of TDMS files (a new file is written every 1 million samples). I am able to save the data at sampling rates up to 100 kS/s/channel. However, beyond 100 kS/s/chan, I consistently get the 200279 error. Ideally, I would like to log the data at (up to) the maximum possible rate - 2 MS/s/chan. I have basically concocted my code using the examples provided by NI (one for DAQ board synchronization and one for continuous TDMS file writing). I have tried most of the strategies shown in this article as well as in several related forum posts but I haven't been able to solve this problem. I would greatly appreciate any help in this matter.
Suhas
(3,959 Views)
Hi, here you can find a description to the problem. I recommend opening the NI Example Finder and look at the example located in: Hardware Input and Output»DAQmx»Analog Input»Voltage - Continuous Input. Increase the buffer as mentioned in here (use 20M) and the problem should go away. I hope this helps
Alejandro C. | National Instruments
(3,946 Views)
I meant to link the very same article you have provided but I prpbably forgot to actually create the link.In any case, yes, I have read through the article and tried a few tricks.
The most helpful fix was to increase the number of samples / channel to 10 million. Regardless, i am still limited to about 125 kS/s/chan sampling rate. I would like to bump this number up to 1 MS/s/chan.
(3,929 Views)
Take a look at the attachment. I increased my buffer and I'm able to run at 1 MS/s/chan.
(3,907 Views)
I tried increasing the buffer using your suggested method. I must admit it has improved our acquisition performance quite a bit. However, at sampling rates >= 1 MS/s/chan, I can only acquire data for about 20 secs or less. I need to acquire data over a 4.5 min period (at most) and I am trying to bring this down. Are there any other tweaks I could use to avoid this error and continue sampling at high rates?
Thank you so much for all your suggestions
(3,894 Views)
If the recommendations on the article linked above are not enough then what is left is to add more RAM to your PC or to use a faster computer, as explained here (see Part I). If you managed to read the samples from the buffer faster then the problem should go away.
(3,882 Views)
We have a NI PXIe-1082 that already has a i7 quad core processor and I have upgraded the RAM from the provided 2 GB to the maximum allowable 8 GB. I am not certain that we are having hardware limitations.
In any case, for time being, we are able to manage since we can acquire at 500 kS/s/chan for > 4 mins. So, thanks for the help.
(3,874 Views)
