Multifunction DAQ
Error 200251
Im using NI DAQ 6024-e (PCI) series with BNC 2120.In my experiment i generate a Sine wave of desired frequency and amplitude using labview,
and using daq the generated ac signal is given across the 10k pot placed externally and whenever the resistance is varied, the amplitude
change of the waveform has to be seen in the frontpanel of the VI ,when given through daq back to labview.But I face a problem of not acquring the
waveform with the varying amplitude and with the 200251 error.What can i do?How can this error be overcome and the varying
amplitude be viewed?
(3,421 Views)
could you post your vi? probably we could take a look at it and suggest better
Meanwhile see if the solution provided in this link will help you
http://digital.ni.com/public.nsf/allkb/1875FA9C10356B8986256D21004CDE9C
Message Edited by devchander on 01-19-2007 12:29 AM
(3,413 Views)
