Multifunction DAQ
Error 200077 - NI USB-6008
I bought a NI USB 6008 (DAQ); I'm going to manage its output with a Visual Basic 6 code. But when i try to run the NI-DAQmx Examples for Visual Basic 6 (included in the DAQmx software), an "Error 200077" appears. Could anyone help me to detect which could be the problem?
The example code I tryied to run is "OneSample" (it acquires a single reading from aslowly varying voltage signal).
Thanks in advance,
Regards
Andrea
(3,408 Views)
Hi Andrea,
I've read your post but I'm not sure what you like do: acquire or generate
This document could help you.
Ciao!
______________________
Simone S.
Academic Field Engineer - Med Region
(3,388 Views)
Thanks, the link you posted helps me..
Andrea
(3,385 Views)
