Multifunction DAQ
Error 1 on Data log File Write
I am writing a cluster to a datalog file and I continually get Error 1 an input parameter is invalid or GPIB Controller must be in charge. If anyone has experience with this issue then I could use some advice
(2,657 Views)
Make sure you have the directory C:\Drag Projects. When I first ran your VI i got error code 1. The reason why is because I don't have that directory. After I created the folder the VI ran without any issue.
(2,657 Views)
