07-27-2019 08:39 AM
E Series and X Series Card Synchronization with RTSI cable. Help I have a PCI-6024E card and a PCIe-6320 card plus a RTSI cable to link them together can someone help me with some code to get their timing aligned. Thanks
Wes Callahan
07-27-2019 01:07 PM
1. You'll need to go into MAX to configure it to know you have a RTSI cable in your system and that those 2 devices are attached. DAQmx uses this configured info when it figures out what signal routing it can do automatically on your behalf.
2. After that, it may be as easy as making a distinct AI task for each device, but configuring timing for "Dev2" (or whatever) to use the signal "/Dev1/ai/SampleClock" as the sample clock for Dev2. DAQmx can then do the signal routing work over RTSI for you automatically.
The only other thing to do is make sure you start the Dev2 task first, so that when Dev1 is started later and makes its first sample clock, Dev2 is already looking for it. That'll keep sampling aligned.
-Kevin P
07-28-2019 08:09 AM
Please check this link
http://www.ni.com/tutorial/3615/en/
Thats how its setup years ago with TWO 6024E cards but now i have only 1 PCI slot available in the new computer...
So when i did this the time isn't syncing and i think it has something to do with the 10MHz vs 20MHZ..
Please give me input thanks,
Wes C.
07-28-2019 08:09 AM
Special case – E Series and M Series Synchronization
E Series devices have been leading the market for data acquisition products for many years, and with the introduction of the new NI M Series devices, we feel strongly that NI multifunction data acquisition devices will continue to lead the market. As a result, it is important that current E Series users be able to use both E and M Series devices simultaneously. For this reason, this section presents the recommended method for synchronizing E Series and M Series devices.
E Series and M Series devices employ slightly different techniques for synchronization. To synchronize operations across multiple E Series devices, one device will export its 20 MHz master timebase to be used as the master timebase for the other devices. Although an E Series device can input a slower signal, such as 10 MHz, for its master timebase it cannot multiply that timebase up to re-create a 20 MHz timebase. Therefore, the resolution of the internal sample clocks that the E Series device could create by dividing down this external master timebase would be decreased. M Series devices cannot directly route out their internal 20 MHz timebase over the RTSI bus. M Series devices are able to directly route out only their 10 MHz reference clock. Therefore, the E Series device should be used as the master device when synchronizing an E Series and an M Series device. In this case, the E Series device can route out its 20 MHz master timebase to be used as the reference clock source for the M Series slave. The timebase on the M Series device would then be in phase with the 20 MHz master timebase of the E Series device.
Another behavior difference that must taken into account when synchronizing E and M Series devices is the difference in the default sample clock delay. The sample clock delay is the delay between when the AI Sample Clock occurs and when the first AI Convert Clock pulse for that scan occurs. With E Series, this default delay is 2 ticks of the master timebase, which is the minimum value allowed. With M Series, the default delay is 3 ticks of the timebase being used. Therefore, to more precisely synchronize an E Series device with an M Series device, change the E Series device to have a sample clock delay of 3 ticks. Figure 8 below demonstrates this behavior.
Figure 9 is an example on how to synchronize an acquisition between an E Series and an M Series device.
07-28-2019 08:15 AM
07-28-2019 08:21 AM
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019M5PSAU&l=en-US
07-28-2019 09:39 AM - edited 07-28-2019 09:40 AM
I'm gonna let you in on a secret. Ok, well, *secret* really isn't the right word because I've been half-shouting about it for probably 15 years around here.
The secret to DAQ sync is *often* very much simpler than what a lot of the official docs recommend. The docs aren't *wrong*, but some of the things being advocated are simply *overkill* for many normal needs.
When I'm syncing tasks, I very commonly do it via shared sample clock alone for tasks with the same sample rate. When they have different sample rates, I derive one sample clock from the timebase used by the other.
No trigger config, no reference clock mucking about, no PLL frequency settings. Just shared clocks.
I've only once ever dealt with reference-clock based sync, and that was a system that had a couple dozen DAQ boards spread across 2 PXI chassis, some of which were very special purpose and could *only* be tied in to the master timing system by phase-locking on a reference clock.
In many of the cases where triggering is required, I still don't share the trigger. I just treat the triggered task as my master task, share its sample clock to other tasks, and make sure I start all the slave tasks before the master.
There's so much discussion about sync here on the forums that I'm having trouble finding one that's especially good and clear. In the meantime, here's a small example I posted that illustrates how I did sync via shared sample clock alone. They were AO and counter tasks, but the exact same DAQmx timing-related code would apply to AI. There's better examples around, I just can't seem to unearth one at the moment.
Your old method for sync is very likely to be overkill, more complicated than what you really need, and you probably didn't reap any benefits from that excess. I strongly suggest simplifying the sync *method* as the first step toward resolving the errors. The simple stuff I advocate is more universal with fewer device-specific exceptions or quirks.
-Kevin P
