Multifunction DAQ
Dynamic event with global variable (vi)
I have registered a dynamic event to fire when a control in a global vi value changes. All works fine when I open the global vi and change the value of the control manually. When I have another vi modify the value of the global, the dynamic event does not fire.
I have tried leaving the front panel of the global vi open and observed the value being changed...
Any help appreciated...
(2,726 Views)
Please refer to the following document that explains why programmatic changes to the global doesn't get detected.
Event Structure Does Not Capture the Value Changed Event...
I hope this helps.
Sincerely,
Feroz
(2,726 Views)
