Multifunction DAQ
Dynamic Data and Multifunction DAQ Issues
I am having significant issues with a Multifunction DAQ (PCI-6220) and Dynamic Data. I have done many DAQ applications but this one requires a mix of Analog, Digital, adn Counters. See description below and attached code. This is in LabVIEW 7.1 format. Thanks in advance for any help with this issue.
Test Method
- Generate clock (CTR1) out on PFI.13
- Jumper clock to PFI.1
- Use PFI to trigger all acquire VIs: Analog, Digital, and Counter
Issues
- Can't merge 1-D digital Waveform to other Dynamic Data
- Want to merge to write data to file in single LVM file
- All data must have labels before writing to disk in LVM format
- Digital Waveform has no plot labels
- Merged Dynamic Data for multiple analog and encoder count
- Plot label form encoder count did not merge
- Not sure Clock Generation will work to trigger acquires
- I get error -50103 when run in sim mode
- I don't have access to equipment for a few more days
- Encode data is off by a factor of 100, WHY?
- Analog and Count Encoder have same number of samples to take
- Data is the same but dT is off by 100
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(3,244 Views)
Some further discussion found here.
I'm going to (try to ) divert further followups from that thread to this one because LabVIEW general threads roll through to new pages pretty quickly.  This MIO board is easier to keep track of.
-Kevin P.
(3,236 Views)
Posted in both locations becuse it was a Multifunction DAQ issue and LabVIEW.
Thanks!
Matthew Fitzsimons
(3,232 Views)
