Multifunction DAQ
Driver uninstall/re-install problems
I'm using a DAQPad-6020E and a SC-2345 signal conditioning unit.  I configured the channels in one version of MAX, then had to instead use a different version so I uninsalled the one with my configurations in it.  The problem is that even after uninstalling (including LabVIEW and using regedit for the files I could directly attribute to NI), the old channel configurations keep cropping-up in the newly installed MAX causing an error, even after by-passing the send/don't send error message box and deleting the channel configurations.  QUESTION:  WHERE ARE THESE CONFIGURATIONS STORED AND HOW DO I GET RID OF THEM?
(3,043 Views)
Hello Tekuser,
Go in and delete everything in the data folders under C:\Program Files\National Instruments\MAX. Then uninstall MAX and NI-DAQ from Add/Remove Programs in the Control Panel. Reinstall NI-DAQ. The configurations should be deleted. Please let me know if you still have problems. Have a great day!
Sincerely,
Marni S.
(3,028 Views)
