Multifunction DAQ
Does the attachments hould be updated?
The attachments above should be updated?
I have a application build with RAD Studio 2007 & NI-DAQmx 9.1.1(with the NIDAQmx90.zip), using hardware NI-9213 & cDAQ-9174. It runs functional.
When I upgrade my RAD Studio from Version 2007 to Version 2010, I get a link error: "Can not find '.OBJ'". however, I don't know exactly how to do. So I delete the SourceCode related to NI-DAQmx in my project, and recompile it. It successes!
So, I think, the attachments should be updated?
Sorry for my poor English, the following is in Chinese 🙂
我用NI-9213、cDAQ-9174构建了数采系统,然后用RAD Studio 2007结合NI-DAQmx 9.1.1开发了软件,软件中用到了这里提供的NI-DAQmx.lib(NIDAQmx90.zip中的)
很幸运,软件编译没有任何问题,而且运转正常。
前不久,我的RAD Studio从2007版升级到2010版,我的程序编译能通过,但link的时候报错,错误信息大概就是"Can not find '.OBJ'",未找到错误根源,我尝试了很多方法,最后发现,只要将源代码中关于NI-DAQmx的部分注释掉,编译就能通过,由此,我初步判定是这里提供的lib文件与RAD Studio 2010不相容。鉴于RAD Studio
2010与之前2007版的最大区别是Unicode,我怀疑nidaqmx.lib文件在转换时忽略了unicode的一些细节?
很期望老大们的答复,如果有更新版的lib文件,请一定第一时间通知我(如果能用中文最好了)。
我的邮箱:yf.jacky@gmail.com或者yf_2100@163.com
http://digital.ni.com/public.nsf/websearch/B09727F89DA3A06C86256F430071D88E?opendocument&Submitted&&...
我用NI-9213、cDAQ-9174构建了数采系统,然后用RAD Studio 2007结合NI-DAQmx 9.1.1开发了软件,软件中用到了这里提供的NI-DAQmx.lib(NIDAQmx90.zip中的)http://digital.ni.com/public.nsf/websearch/B09727F89DA3A06C86256F430071D88E?opendocument&Submitted&&...很幸运,软件编译没有任何问题,而且运转正常。
(3,706 Views)
no one help me?
(3,685 Views)
Howdy DEVED!
I'm not sure I fully understand what you are asking.  If you are encountering errors using NI-DAQmx 9.1.1 with NIDAQmx90.zip then please uninstall DAQmx 9.1.1 and install DAQmx 9.0 which can be downloaded from here.  The problem you are encountering sounds like the files in NIDAQmx90.zip are not linking correctly to NI-DAQmx 9.1.1.
Barron
Applications Engineering
(3,672 Views)
