Multifunction DAQ
Does the 6239 slew rate varry?
I am using two PXI-6239 Multifunction DAQ cards to create a biphasic output current wave.  For one application where I need the current outputs to be 20mA and 1mA it works just fine.  When I try and use the same exact code but at much lower current output, like 80uA, I'm getting rise times much slower than the expected .8uS.  The specifications state a .1mA/uS slew rate and I'm wondering if there are any restrictions to that or if there is some nuance that I'm overlooking.  Any help would be appreciated.  Thank you,
Erich
(2,944 Views)
Erich,
How are you measuring this slew rate/amperage?  If you just measure across a resistor do you get the same results?  Please make sure the circuit you are attaching to doesn't have inductive or capacative elements.
Sincerely,
Jason Daming
http://www.ni.com/support
(2,923 Views)
I was measuring the voltage through a PXI-5922 Scope card and across a resistor.
(2,920 Views)
