Multifunction DAQ
Distorted Output with NI 9263
I am currently working on a project but I have run into a road block.
I cannot get my DAQ to output a clean signal I and I am sure what I am doing wrong. I am using a NI 9263 DAQ with a NI cDAQ 9172 chassis. I made a very simple vi to test the hardware but the results are not very good, and even when using a 96kS/s sampling rate to generate a 1kHz signal produces rather poor results.
I have included the vi I used to test the hardware and pictures of the output. Any help would be greatly appreciated.
(4,127 Views)
You increase the number of samples you're using on the DAQ assistant and the wave generator, it's a pretty low value, so it's probably unable to create the waveform appropiately.
(4,057 Views)
