Multifunction DAQ
Displacement Measurement Cards
Is there a C series module for Displacement sensors like there is 9234 for accelerometer? If yes which one is it and does it go with both cDAQ and cRIO?
thanks
(2,032 Views)
All the measurement cards measure electrical parameters such as voltage or current. The sensor that you use determines what kind of real-world signal (displacement) is converted to an electrical signal. If you could share the datasheet of your displacement sensor, we can suggest you C-Series cards that could measure those signals.
Santhosh
Soliton Technologies
(2,024 Views)
It would be great help if you can suggest a displacement sensor thats most commonly used  and the c series card to go along with it.
Thank you
(1,982 Views)
Unfortunately, I am not familiar with displacement sensors to recommend one, but if you can select one, I can recommend a bunch of compatible C-Series cards.
These articles came up on google
https://www.keyence.com/ss/products/measure/library/basic/howto_select.jsp
https://mtiinstruments.com/knowledge-center/selecting-displacement-sensor-measuring-system/
https://www.solartronmetrology.com/about-us/press/press-releases/press-releases-and-events/2020/nove...
https://www.measurex.com.au/technical-tips/how-to-select-ds/
If you are not in a position to select one, I would recommend reaching out to a NI alliance partner experienced in turn-key electro-mechanical automation solutions.
Santhosh
(1,969 Views)
