Multifunction DAQ
Disable a control using conditions.
I am trying to disable a control on the front panel based on the status of other contorl and indicator states. Is there an easy function that I can call to enter the allowable conditions versus the non-allowable ones?
(2,818 Views)
Dear Plasmaticon!
Thank you for choosing National Instruments!
Addressing your issue of disabling controls depending on certain conditions, there is, unfortunately no function to do this.
However, there is a powerful feature in LabVIEW which is pretty straight forward to use - called Property nodes. You can create a property node for each control on the front panel by right clicking on the control and selecting Create > Property node. You can also then manipulate the front panel control by means of this property node - including enabling and disabling the control at will depending on when certain conditons are met.
We hope this helps.
Thanks and Regards
ShekharS
National Instruments.
(2,810 Views)
