Multifunction DAQ
Digital output delay
Hello
I need to produce 2 pulses with 2 digital output but with 100us delay between them
i am using pxi 6363 .. is it possible?
can i do it with NI MAX?
thanks
(1,451 Views)
6363, an X Series DAQ module, supports hardware-timed digital tasks on port 0.
You can refer to the shipping example at Help >> Find Examples >> Hardware Input and Output >> DAQmx >> Digital Output >> Digital - Finite Output.vi
Use Onboard Clock as the sample clock source. Set sample rate to 10k (or 0.1ms). Then write data of 3,0,3,0 (0d3 or 0b11)
https://tmesystems.net/
(1,400 Views)
Hi
thanks for your reply
I don’t understand , how can I perform a delay between 2 different i/o with that example?
regard,
moran.
(1,376 Views)
Why not use a seperate monostable, e.g. a 555 timer?
(1,290 Views)
