Multifunction DAQ
Digital output Problem
Hi James,
I am trying to do something similar to this example in a USB 6259 (M series), but I need a rate of 8 MHz.  Is that means that I need to put the number of samples to 8M and generate an array with that number of elements?
As the buffer size is limited to 1M, I do not understand very well how it should be configured.
I have tried creating an array with 1M elements and setting the number of samples and the buffer size to 1M, however it does not work up to 8 MHz. The maximum frequency I can get is 5 MHz.
The datasheet says that this DAQ can work up to 10MHz in the digital IO. Do you know if I am doing something wrong?
cmora.
Message 11 of 15
(1,496 Views)
Hi cmora,
Could you explain a little more what tasks you are trying to perform with your 6259?  It sounds like  you are trying to output a pulse train at 8 MHz? Are you using any of the example programs?  You should be able to output 8 MHz.  You should start with the Correlated Dig Write with Counter.vi example program located in the Example Finder.  You can find this example within LabVIEW at Help >> Find Examples.  Then double click Hardware Input and Output >> DAQmx >> Digital Generation >> Correlated Dig Write with Counter.vi.  When you say that your can only get to 5 MHz, how did you test this?  Did you get errors above 5 MHz?
Jim Schwartz
Message 12 of 15
(1,463 Views)
Hi, Jordan,
I have a similar question. I am using PCI 6602. The goal here is to get continuous 1MHz square wave output from DIO1~32 sequentially controlled by LabVIEW.  I used Ctr0 to generate a 2MHz clock and used Ctr0InternalOutput as sample clock of DIO1~32. I attached the code and screeshots as follows. But when I run it I got an error -200077 (you have requested: sample clock; you can request: on demand). It looks like PCI 6602 doesn't support hardware timing. Is that true? Where can I find this? If it is true, how can I avoid this and get what I want? Thanks!
Yi
Version: LabVIEW 8.2
hardware: PCI 6602
Message 13 of 15
(1,372 Views)
Forgot to say. The code is working on PCIe 6251. But I need 32 DIO which PCIe 6251 doesn't have.
Yi
Message 14 of 15
(1,371 Views)
Please see my post here.  The 6602 unfortunately does not support clocked digital waveform generation.
If you need 32 clocked digital lines then I would suggest either the PCI 6224, PCI 6254, PCIe 6323, PCIe 6353, or PCIe 6535.
Best Regards,
John Passiak
Message 15 of 15
(1,354 Views)
