Multifunction DAQ
Digital counter cannot count
I am using PCIe-6323 and BNC 2110 to build a digital counter. I generate a continuous pulse on PCI 12 as clock source. I set the ttl rate as 1000. I use CTR1 OUT to get the signal I need to count. I use a function generator as a testing source to test. The input frequency is 10k Hz. It should get counts out. But the count I get is all 0. I also try the example program given in the Lab Windows CVI, but they do not work neither. I try the testing pannel, but that one can count the numbers out. Then I believe that it is not the problem of hardware. Any one has some clues? Thanks!
(3,248 Views)
photoszzt,
What is not working with the examples that you tried?
KyleP
(3,230 Views)
As I plug in the test source(a function generator generating continuous square wave), it counter should get some counts out of the counter. But all I get is 0. I cannot count the number out.
(3,228 Views)
So you have verified the square wave in Measurement & Automation Explorer with Test Panels, but the example is not working? I would double check all of your settings in the example. Make sure you've specified the right devices and lines.
KyleP
(3,216 Views)
