Multifunction DAQ
Digital Pulse in fixed times
Hi all ,
I have the NI USB 6356 and I want to use it's timers to create pulse ,
I want to set a time table for lets say :
0.01 sec
0.04 sec
0.06 sec
0.07 sec
and at each time to do an DO pulse.....Total of 4 pulses.
I've found the some examples with 1 pulse ( high & low time ) but I want to create sevral pulses in different times....
Any ideas ?
Kobi Kalif
Software Engineer
Message 1 of 8
(3,603 Views)
Kobi,
If I'm correct in understanding your project, you're wanting to create multiple pulses each at a particular time whereas you've found examples to do only one at a specified time. Or, for a particular channel, you're wanting to specify a 'changing' time interval between pulses. Which scenario are we looking at here?
Renee M
Renée M
Message 2 of 8
(3,555 Views)
Hi Renee,
It's just like you said but I already found how to it 🙂
The NI 6356 that i have , has an internal clock with one of the DO ports so i use it's clock to create an arrary with values of "1" and "0"
The time diffrence between each array cell that i'm sending throw the DO is determaine by the DO rate so i can calculate the pulse width
Thank you for your response.
Kobi Kalif
Software Engineer
Message 3 of 8
(3,518 Views)
Kobi,
You're quite welcome. I'm glad you found an answer!
Renée M
Message 4 of 8
(3,507 Views)
Hi Kobi,
Another option would be to use one of the counter outputs on the 6356 (there are 4 counters).  You can actually output a buffered array of high and low times using the X-Series counters (see this example--it outputs an array of frequencies and duty cycles but you can change this to high time and low time instead if desired).
The benefit of this method is a higher resolution (there is a 100 MHz timebase available on X Series devices) and presumably also a more simple programming method.  The DO method you have proposed would also work well but it's less straightforward (in my opinion) to build the digital waveforms manually.
Best Regards,
John Passiak
Message 5 of 8
(3,499 Views)
Hi John,
Your sulotion was the first thing i tryied but since i need 5 DO Pulses i'm using PORT0.
I didn't know about the higher resolution so i'll look in to it ,
Thank you.
Kobi Kalif
Software Engineer
Message 6 of 8
(3,491 Views)
Hey Kobi,
If you need 5 pulses then you should probably just stick with the digital outputs on port 0 (rather than go through the extra steps of synchronizing the counters and the DO together) unless your requirements necessitate the use of the counters.
Your initail post said you needed 4 pulses which is why I mentioned the counters.
Best Regards,
John Passiak
Message 7 of 8
(3,478 Views)
You right ,  sorry 🙂 it was an example.
Thank you for your help.
Kobi Kalif
Software Engineer
Message 8 of 8
(3,466 Views)
