Multifunction DAQ
Different input voltage
Hello guys,
I have a problem, with my NI USB-6009. I try to measure a voltage of my wheatstone bridge, my multimeter says it´s 20mV, but my USB-6009 just says that it gets 1,34 V.
Does anyone know how I can fix this problem?
Do I have to calibrate the USB-6009 or does it need a factor to multiplie the input-voltage?
(1,456 Views)
Maybe it´s important to know , I´m using Matlab and just single ended measurement.
(1,452 Views)
Please share the exact circuit connections and also the source code.
Please do note that the accuracy of USB-6009 is typically +/- ~15mV
Santhosh
Soliton Technologies
(1,417 Views)
DMM:
Input impedance?  (>10Meg?)
Impedances to GND? (?)
6009:
Input impedance ?
Impedances to GND?
Impedances to GND of your  bridge supply?
Grap a instrumentattion amplifier (INAxxx) and build a Diff to SE buffer for the 6009...
Greetings from Germany
Henrik
LV since v3.1
(1,379 Views)
