Yes, I am using the Pattern I/O mode. I have gone through the manual. Following is what I want to try to do.
Start the clocks (NOT DATA TRANSFER) one 10MHz and the other at 1.25 MHz. Provide clocks to second 6534 board and one analog board (6110). Now, trigger the the data transfer from all the boards at the same time using the pin named ACK (Starttrig) so that data transfers from each of them will be in sync. Since, the clocks are supplied by one of the boards, CLK edges should match with very negligible delay.
Now, Here are questions.
1. Can I externally trigger the 6534 board? I would like to trigger it form TRIG1 pin of Analog board (if I can supply that trigger to other boards??).
2. Can I internally trigger the 6534 board and supply that
3. Do I have to specify any pre trigger data in or out. I dont want any pre trigger data.
