Hang,
You shouldn't have to worry about the GPIB or PXI entries under Devices
and Interfaces. GPIB is an interface that you can use to
communicate with set-top instruments such as a scope or digital
multimeter, but it won't have anything to do with your 6013
cards. Since your cards are PCI versions, you don't need to be
concerned about the PXI entry either.
To check your current device number assignments in MAX, you will want
to look under Devices and Interfaces, then Traditional NI-DAQ
Devices. You will probably see something like PCI-6013E (Device
1) and then PCI-6013E (Device 2). You will want to make sure that
these device numbers you have in MAX match up with the device numbers
you have in your LabVIEW VI. If you need help with figuring out
your LabVIEW VI, take a look at the manual for the Traditional NI-DAQ
drivers here:
http://digital.ni.com/manuals.nsf/websearch/74E3CF846234B47E86256CB7005DF156
One tip I would also have is to turn on your Context Help in LabVIEW
(Help>>Show Context Help), as it will give you overviews of the
functions you have your mouse over.
Thaison V
