Multifunction DAQ
Deployment a Program using USB 6008
The program is working fine in the developtment enviroment when we compile it, we have an BFFF000E error when we try to use the AI.
We are using an USB 6008 device.
(4,032 Views)
Manuel
I'm assuming you mean that your entire system works great on your development PC, and it's your target system that has problems.
Can you tell me a little information about the setup of your development and target systems:
Operating System
NI-DAQ driver (NI-DAQmx Base 1.x  or   NI-DAQmx 7.5)
Programming Environment (LabVIEW, VC++, VB)
The first thing that I would do would be to verify that you have the same version of the NI-DAQ driver installed on both systems.  Then, open up Measurement and Automation explorer on the target system and test the USB-6008 device.
Travis W
DAQ Enthusiast
(4,021 Views)
Hi, Manuel.
Have you found a solution to this problem.  I'm having the same problem.  I can't run my 6008.exe on the same system where I run the 6008.vi thru LabView.
If you have a solution, I would love to hear what it was.
Alicia.
(3,941 Views)
Hello all,
See my post on this thread.  Your solution is there.
-Alan a.
(3,925 Views)
Are you using VS.NET
Message Edited by VBCoder on 08-18-2008 11:52 AM
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
(3,519 Views)
You are responding to a three year old post.
(3,513 Views)
