Multifunction DAQ
Delphi and NIDAQ
I am using Delphi and the NiDAQ DLL to control a AT-MIO-16DE-10
board, I can control the digital outputs and inputs, but we also need
to read AI channels, Does anybody have any examples (in C if
neccessary) of how to confiqure a AI channel. I have been using the
help but examples would be helpful.
I understand that triggering is not possible with this board, am I
right?
I am planning to use SCAN_Start to log multiple channels, but I am
unsure now to setup the channels, do I use Select_Signal?
I need to log at a rate of ~1ms for upto a second, I think I need
to use double bufferring, correct?
Thanks for any help
Tom Bradshaw
tom.bradshaw@zytek.co.uk
Sent via Deja.com http://www.deja.com/
Share what you know. Learn wh
at you don't.
(2,988 Views)
Tom,
You may be interested in viewing some examples that NI has on
www.natinst.com. For example, I found a Continuous Acquire to File AI
Example in C++ and other DAQ examples at
http://digital.natinst.com/explprog.nsf/web%2Flanguage?OpenView&Start=1&Count=500&Expand=11.1#11.1
Unfortunately, I could not find any AI examples under Delphi, but this
should help a bit...
Rich
tombxx@my-deja.com wrote:
> Hi,
> right?
> Thanks for any help
> Tom Bradshaw
> Share what you know. Learn what you don't.
(2,988 Views)
Iam use AI_read Iam working on to use DAQ_Rate and DAQ_start.
Has anyone examples to use DAQ_op or DAQ_Rate or DAQ_Start.
(2,988 Views)
