Multifunction DAQ
Data aquisition locks computer
The following code causes my computer to lock up.  No response from anything, even Ctrl-Alt-Del.  I have to power off and back on.
#define
DAQ_BUFFER_SIZE 100 // size of buffer to allocate for data aquisition
#define DAQ_DATA_RATE 2000.0
// data collection frequency (Hz)
DAQmxErrChk (DAQmxCfgSampClkTiming(masterTaskHandle, "", DAQ_DATA_RATE, DAQmx_Val_Rising, DAQmx_Val_ContSamps, DAQ_BUFFER_SIZE));
DAQmxErrChk (DAQmxRegisterEveryNSamplesEvent(masterTaskHandle, DAQmx_Val_Acquired_Into_Buffer, DAQ_BUFFER_SIZE, 0, EveryNCallback,
this));
If I change the buffer size to 1000 and data rate to 1000, it works fine.  I need to be able to see the data at least 10 times per second real time.  I need to be able to record the data at 1KHz minimum.  I am reading 4 channels.
Windows XP, SP2
DAQmx 801
PXI-6031E card
 - les
(2,988 Views)
Hi Les,
Try running the example ContAcq-IntClk-EveryNSamplesEvent.c which is installed by default to C:\Program Files\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Events\Every N Samples.  I tried running this example with the parameters you specified (rate = 2000 Hz, buffer size = 100) on 4 channels of an E-Series board, and it worked fine for me.  Let us know if you have any problems with this example.
Message Edited by Jarrod B. on 04-27-2006 11:33 AM
(2,974 Views)
