Multifunction DAQ
Data acquisition using delayed trigger or counter.
Hi,  I'm a kind of novice LabView user.
I have a PCI-6115 DAQ and L.V. 8.2.
Currently I made a data acquisition program with 5MHz sampling rate.
With some reason, I need to get a data in some specific point (time).  I found some good delay output example using counter.  So, I combined two vis, but it does not work well.
I attached my vi. Please look at it and tell me what the problem is.
By the way, I'm using 5MHz external clock for timing and 6.66kHz(150us period) external trigger signal.
Thank you in advance.
(2,842 Views)
Hey kaggie,
Did you get the code I sent this morning?  Let me know if it is not working.
Kenn North
Principal Product Manager - Search, Digital Analytics
http://ni.com/search
(2,827 Views)
