Multifunction DAQ
Daqmx base error:200428
Error code:200428
Value passed to the Task/Chanels in control is invalid
Virhe syntyy ajaessa DIO read esimerkki ohjelmassa
(3,361 Views)
My first suggestion would be to upgrade to NI DAQ Mx 8.0 and completely uninstall MX Base.
the mx base drivers are junk IMHO. That curred my headaches.
Next have you created the task before trying to do an operation with it? Use the vi's DAQMx Create Virtual Channels.vi or DAQmx Create Task.vi. Feed the task out to the start task vi and the read or write vi. Then stop the task when the operation is complete. You should also destroy the task at the end of your sub vi.
(3,343 Views)
Hi Maija,
The problem comes up if you did not configure the task correctly. Follow the instructions in the following document:
http://digital.ni.com/public.nsf/websearch/7705D38D59EF562886256F79007E4B5A?OpenDocument
If you still meet problems please provide more specific information about your development environment, driver version and application. Please type your question in english.
Vesa K
Message Edited by Vesa K on 02-23-2006 08:19 AM
(3,328 Views)
