Multifunction DAQ
DMA programming
I am programming a PCI E series board, without the NI-DAQ, i.e.: register
level.
I have beed probing the examples, but the example 4 (DMA) does not work.
Has this example been probed succesfully by anyone?
(3,355 Views)
Hi, I am trying to do DMA programming too. I got other examples except for Example 4. Could you tell me where to find this example or (if you have it) could you email it to me? Thanks.
flofish (qw4k@virginia.edu)
(3,334 Views)
Hi Ruben,
To begin, what OS are you using? If you are using Linux or Mac, then we have a new driver called NI DAQmx Base that can be used in those operating systems. I am assuming you are trying to run example 4 from the E Series RLP Manual. Unfortunately, we don't support RLP, but the manual does say that unless you are using DOS then you will have to modify the program. I just wanted to make sure you were aware of this driver, and hope that you will find the answers you are looking for. I hope you have a Wonderful Day!
George
(3,328 Views)
