Multifunction DAQ
DAQmxWriteDigitalU8 writing mod
Hi, I'm not sure how DAQmxWriteDigitalU8 function writes 4 digit sample. Does it write 0x04 data like 0000 0100 or just 0100 0000 ?
Looks like DAQmx ignores first four zero bits.
Here is a testing code
#define TEST 0x04
DAQmx_Digital_Output(taskHandle, NATDEVICE_NUM1, PORT_A, TEST);
int32 error=0;
int32 numWritten = 1;
if(DevNo == 1 && PortNo == 2){
DAQmxErrChk (DAQmxCreateTask("", &MX_DO_Handle));
DAQmxErrChk (DAQmxCreateDOChan(MX_DO_Handle,"Dev1/port1","",DAQmx_Val_ChanForAllLines)); // it has 8 lines
DAQmxErrChk (DAQmxWriteDigitalU8(MX_DO_Handle,1,1,0.0,DAQmx_Val_GroupByChannel,&iDataToWrite,&numWritten,NULL));
if(!error && iDataToWrite == 0x04){
printf("Writing iDataToWrite: 0x%X\n", iDataToWrite);
else
printf("Writing failure!\n");
From if(!error && iDataToWrite == 0x04) code, whatever I wrote it like == 0x4 or 0x04, it passes the condition without an error.
I wonder if DAQmxWriteDigitalU8 writes the data like 0100 0000. It should be 0000 0100.
I'm converting DAQ to DAQmx..from Parkoz.com
(4,316 Views)
Accepted by topic author anarkie
If you write 0x04 to an 8 bit port, then what you get out is:
line 0 - 0
line 1 - 0
line 2 - 1
line 3 - 0
line 4 - 0
line 5 - 0
line 6 - 0
line 7 - 0
line 0 is the lsb and it's no different in DAQmx than it was in traditional DAQ.
(4,311 Views)
