Multifunction DAQ
DAQmxWriteDigitalLines Problem
my device is USB6009
uInt8 data[100];
data[1]=1;
DAQmxCreateTask(" ",&taskHandle1);
DAQmxCreateDOChan(taskHandle1, "Dev1/port0/line2", "",DAQmx_Val_ChanForAllLines);
DAQmxStartTask(taskHandle1);
DAQmxWriteDigitalLines(taskHandle1,1,1,10.0,DAQmx_Val_GroupByChannel,data,NULL,NULL);
When i execute the following code which is written in Visual C++6.0  the bulb on the circuit  does not glow which it should.But i'm able 2 read from line2 which means there is no problem with the line.The write digital line is working perfectly in Visual Basic where it is something like this
DAQmxErrChk DAQmxCreateTask(" ", taskHandle1)
 DAQmxErrChk DAQmxCreateDOChan(taskHandle1, "Dev1/port0/line4", "", DAQmx_Val_ChanForAllLines)
 DAQmxErrChk DAQmxStartTask(taskHandle1)
DAQmxErrChk DAQmxWriteDigitalLines(taskHandle1, 1, True, 10#, DAQmx_Val_GroupByChannel, writeArray(0), sampsPerChanWritten, ByVal 0 & )
Can somebody help me.
Message Edited by perk_bud on 12-08-2006 05:54 PM
(4,082 Views)
I even tried this example given in the examples section with the NIDAQ software.
#include <stdio.h>
#include <NIDAQmx.h>
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else
int main(void)
    int32       error=0;
    TaskHandle  taskHandle=0;
    uInt8       data[2]={1,0};
    char        errBuff[2048]={'\0'};
    // DAQmx Configure Code
    DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
    DAQmxErrChk (DAQmxCreateDOChan(taskHandle,"Dev1/port0/line1:2","",DAQmx_Val_ChanForAllLines));
    // DAQmx Start Code
    DAQmxErrChk (DAQmxStartTask(taskHandle));
    // DAQmx Write Code
    DAQmxErrChk (DAQmxWriteDigitalLines(taskHandle,1,1,10.0,DAQmx_Val_GroupByChannel,data,NULL,NULL));
Error:
    if( DAQmxFailed(error) )
        DAQmxGetExtendedErrorInfo(errBuff,2048);
    if( taskHandle!=0 ) {
        // DAQmx Stop Code
        DAQmxStopTask(taskHandle);
        DAQmxClearTask(taskHandle);
        printf("DAQmx Error: %s\n",errBuff);
    printf("End of program, press Enter key to quit\n");
    getchar();
    return 0;
What i cant understand weather the glowing of the bulb happens so fast that i can't see or is there a problen with the code.By the way the bulbs on line 1 and 2 are in off state and i'm trying to on them.
Message Edited by perk_bud on 12-08-2006 06:07 PM
(4,075 Views)
Plz help
(4,047 Views)
Sorry guys my mistake i found out that the wire was a bit loose now it's working perfectly.Thanx anywaySmiley Happy
(4,045 Views)
