Multifunction DAQ
DAQmxIsTaskDone() & DAQmxBaseIsTaskDone() bug
The code below generates an erroneous result:
DAQmxBaseCreateAIVoltageChan(taskHandle, ...., NULL);
DAQmxBaseCfgSampClkTiming(taskHandle, ...);
DAQmxBaseStartTask(taskHandle); // starting data acquisition
loop_start:
DAQmxBaseIsTaskDone(taskHandle, &isTaskDone);
/// isTaskDone is always 1!
if(isTaskDone == 0) Do_Something();
loop_end:
iStatus = DAQmxBaseReadAnalogF64(taskHandle, ....);
In the code above the DAQmxBaseIsTaskDone() function after starting the data acquisition task always returns a 0x1 value (task done).
The isTaskDone flag should be initially 0 (zero) and change to 1 after completing the data acquisition task.
(3,502 Views)
If you look in the Read Me file that is installed with DAQmx Base, you will find, "DAQmxBaseIsTaskDone does not currently support analog input."
Oh, well. Seems like an important one, eh?
John Weeks
WaveMetrics, Inc.
Phone (503) 620-3001
Fax (503) 620-6754
www.wavemetrics.com
(3,493 Views)
I have to correct myself, the DAQmx vesion of the function works correcly.
I had a bug in my test program...
(3,483 Views)
Thanks, I overlooked this. This is not documented in the C Function Reference Manual.
Yes it is.
Without a bug-free DAQmxBaseIsTaskDone() or DAQmxGetReadAttribute() which is currently not implemented in DAQmxBase it is impossible to port an existing program to DAQmxBase.
Regards:
Bela Torok
(3,481 Views)
