Multifunction DAQ
DAQmxGetSysDevNames
Can any one tell me more about "DAQmxGetSysDevNames" function call? Such as the meaning of return type and how the device name string are organized in the returning buffer, and the marks to parse them out? Thanks.
(4,969 Views)
Phoenix T,
int32 __CFUNC DAQmxGetSysDevNames(char *data, uInt32 bufferSize);
The return type is the error code returned by the function in the event of an error or warning.  A value of 0 means no error, a positive value indicates a warning and a negative value indicates an error.
I ran a C program that uses the function and "data" came back with the string:
Dev1, Dev2, Dev4, SC1Mod1
So you can parse out the devices by looking for commas.  I hope this helps but let me know if I can do anything else for you.
Jeff Tipps
(4,939 Views)
